Almost ready to give up and make new injector lines using copper/nickle brake line. The line coming out the bottom of the CAV pump started leaking last year at the pump fitting. Bought a couple used adapters off eBay and a new set of injector lines from this site. Replaced all 3 lines which was a project in itself and made sure the adapters didn't have any cracks and looked OK, installed the best 3 I had. Seemed to be OK till yesterday and now the same line is leaking again.
Those fittings at the pump are a bear to get a wrench on and I have tightened it as much as I dare. Is this a common problem and anything other than the fitting/line and adapter be causing this? Wondering if the injector may be requiring too much pressure although I had all 3 rebuilt a couple years ago.
Any other ideas other than making new lines out of something easier to work with.
