Eaton Power Steering Pump Lid Seal
CTPhil
Has anyone ever gotten a replacement lid seal for a xx1 model by crossing to a Ford car pump of the same vintage? Apparently several models used that pump, and I've found sources, including local auto parts stores, but there are apparently different part #s for the seal depending on whether the vehicle has A?C or not. Anyone have any insight on this?
Theres a complete seal kit I have used made for the cars and there are also just the lid seals on fleabay. You might question them as to in,out and thickness of their seals. Did yours get too flat to hold? Do you have any trouble with moisture getting into the system? I have been using ATF in them but I think I'm going to switch to the green Penrite LHM mineral oil as its hydrophobic. I'll try to find that kit I had.
