Let's talk about sediment bowl
grandpa Love
Ford 640 and 960. Neither one has a sediment bowl. Both run fine and have for the 3 years I've had them.Gas tanks are nice and clean. I get comments at tractor shows that the bowls are missing. Any need to add them? I know the 960 bowl goes by the carb, how about the 640? You guessed it,it's raining in Central AL so I'm stuck in the house! Thanks for any input on this too!
Unless your a tractor purists and want authenticity it?s not necessary, just have an inline fuel filter between the tank and the carburetor and your good to go, When i replumbed the fuel lines on the Moline I had earlier I took sediment bowl off and went with an inline fuel filter and installed a ball valve upstream side of carburetor to keep gas turned off when not in use
