Home Machinist
I own a Ford NAA tractor was running fine all week and early today but it started sputtering and idling rough. Looked it over took off the glass fuel bowl cleaned it and opened the pet cock when I noticed it fuel filled it up but really slow. Took the bowl back off turned the gas on with out it came out as should. Put bowl back on and started to trace and found flowing into the carb was at fault the elbow screen is clean but when the system is closed it trickles out if a open the pet cock on the bottom of carbuator bowl that I installed it flows out but system closed it seems like an air bouble form like a plugged vent preventing adequate fuel from flowing or stuck float in the carbuator.
Thankyou;
Travis
Thankyou;
Travis
