OregonAaron
Hello, I have a 75 ford 2000 and someone
before me converted the fuel system to
gravity feed. I know this is not right so
I purchased a fuel pump and installed it.
Now the tractor runs very badly and the
carb pukes fuel out of the bottom. So I
put it back to gravity feed (for now) and
pulled the carb off to have a look at it.
I did not open it because I do not have
new gaskets, however I noticed the fuel
inlet was jb welded in and there is a
large crack in the casting that was jb
welded as well. So I figure I should bite
the bullet and order a zenith carb for it.
My question is, will the zenith carb work
well with gravity feed or does it prefer
the 4 psi of the fuel pump?
