1954 Ford NAA
I have a question regarding my NAA tractor was using today running fine then all the sudden it started sputteren didn’t die on me has fuel got down of it to double check and that’s when I noticed the top tank of radiator colasped some. I’ve never incountered anything like that and was concerning thought I better ask.
Thankyou;
Travis
Did the tank collapse or the radiator hose, I don?t follow you
when you say tank collapsed, if you meant the hose collapsed
then I would replace the radiator cap and go from there
I have another question today using it noticed it began to sputter after doing some looking over found it to be fuel starving not getting enough fuel. Took everything apart from fuel bowl, fuel line to elbow with screen out checked for blockages none. Noticed fuel was slow to fill glass bowl but take the line off at carbuator and it free flowed as should. To me something is blocking the flow of fuel into the carbuator such as a vent looking for suggestions was running fine till today. I wonder if some Sea Foam might work clean out what ever the problem is like old gas turns into varnish.
Thank Your;
Travis
