FordTractorMan
Hi all. Not sure what happened, but I got my 5000 w/SOS out of the shed yesterday to spray, put pto in gear while filling sprayer, then it looked
rainy. I disengaged the pto, and the lever came forward freely - no resistance at all. I found the little detent stud that screws in the hole w/the
spring behind it lying on the footboard. I threaded it back in this mornining, but that's all. I plan to knock the roll pin out of the handle and turn
the shaft to where the slot in the bottom of the handle will fit back over the detent. Is that all I need to do, or has something gotten out of line
inside that will need attention? Did I explain this well enough?
