Blueford4000
Two problems. At idle engine dies. At fast idle engine lopes.
Engine starts cold with no choke....if you choke it, engine floods.
This is not a problem, just describing it.
I suspect carb problem as these symtoms point to a lean mixture. Is there a way to rule out manifold leak as cause of lean mixture, or is that not even worth pursuing.
Any help is appreciated.
