supermechanic
New User
Hello, I am having difficulty identifying a Ford tractor.
I had believed it was a 3400, but now the further I look , the more unsure I am.
Numbers on the clutch housing(above where the starter bolts in) show as:
5M2CCB
34021G
C131505 6C14
Tractor is 3 cylinder, gas. Has FEL. Exhaust goes up.
Transmission is dual range, stick on right is hi-lo.
Stick on left is h pattern f1 and f2 on top, r1 and r2 on bottom, so in all, there are 4 speeds forward, 4 speeds reverse.
Has power steering, a non adjustable front axle, 3 point hitch, no pto.
Also has 12 volt Lucas generator electric. Dry , outboard brakes.
I have owned this for more than 20 years, has been the most reliable machine, can sit for months, will start with no problem.
It is now time to do some repairs, maybe get some new sheet metal to make it pretty. Would be nice to know exactly what it is, thanks, Ed.
5M2CCB
34021G
C131505 6C14
