Jubilee Tractor
pinball
I am looking for a seat assembly for a ford jubilee tractor. ALSO looking for a draw bar and a good service manual. Just looking for good used parts. Hopefully in Missouri. thanks for looking
You can get new aftermarket seats and 11-hole drawbars at most every Ford Tractor Parts sellers, including this site. Original used ones are always on the popular auction sites as well. Ford used the standard 8N-400 pan seat on the NAA (Jubilee) Model. This was hinged/flip up style that was an improvement over the earlier 9N/2N non-flip up pan seat. If you are looking for something other than that, there were options available which included the Monroe EZ-Ride Seat; the Knoedler Seat; and the Rest-O-Ride Seat. None of those are made aftermarket today but originals also pop up online. Most of the time they are worn out and need rebuilding -not always easy, nor cheap to do, providing you can even find new parts. The EZ-Ride and the R-O-R seats do offer some newer parts, but the R-O-R seat is the better choice out of all four. The R-O-R seat uses your original 8N-400 pan seat but the ride is cushioned better with large rubber spring loaded bumper/shock absorbers. Ford eventually went with R-O-R seat as standard OEM part on the Hundred Series tractors. If you are referring to a swinging drawbar and not the OEM 11-hole horizontal drawbar supplied with each new tractor, then there are kits available with (11-hole ones too) at most sellers around town. For a good NAA service manual, get an I&T F-019 manual available at part sellers everywhere, including this site. I'd also invest in a copy of the '39-'53 MPC -it has the NAA Model in it as well. HTH...
Tim Daley(MI)
