Ford 100in Shredder
miner09
Anyone know the number of the pull type Ford Shredder made in the 60's. It has a
number but we always called it a 100 inch shredder. The tag only has 22-126 and
serial number. I need a decal.
I couldn't make out the decal but it looked like 901-601 so it has to be the 902.
Ford decal is on right side and the number was on left side. We've had the cutter since it was nearly new. Just cleaned it up and painted it. Very good cutter. Thanks a lot.
I had a model 902, also called 100 inch shredder. Belt-driven. I never thought I'd like the belt-drive as well as shaft-drive, but I believe that was the best shredder I've ever owned. I only changed the belts once in the 10 years I owned it. I didn't replace both belts at the same time, and I didn't get the tensioner adjusted the same for both belts, so I caused one belt to get chewed up. When I got the tension evened up, it worked fine.
Butch
