JeffG in WI
I have an 860 that needs a gas tank repair or replacement.
I also have an Jubilee. I really like the gas tank/sediment bowl/carburetor setup on the Jubilee.
As for the 860 setup, well, I'm not a fan of gas dripping down onto the engine from the shutoff valve when the o-ring gets tired, or the fuel line getting super heated as it runs behind the manifold.
So my question is this: On my 860, can I replace the original tank with the NAA600800G tank from this site, and then use the outer edge threaded opening for a Jubilee-style sediment bowl? I would then remove the existing sediment bowl and banjo bolt from the 860 carb and replace it with an elbow and strainer assembly, so the fuel line could go straight into the carb from the sediment bowl mounted up on the gas tank....similar to how it's done on the Jubilee.
Has anyone tried this and does it work, or am I overlooking something?
Thanks!
Jeff
Thanks!
Jeff
