851 ford diesel pto quit work
itmeagain
finely got some time off.. pull out PTO it came out into two piece right there about 6 inch where the pins hold in shaft it broke and other part of driveshaft pull right out there no missing part . of shaft did drain the oil found no metal was found so i need to find a one ..
(quoted from post at 11:14:06 06/15/18) finely got some time off.. pull out PTO it came out into two piece right there about 6 inch where the pins hold in shaft it broke and other part of driveshaft pull right out there no missing part . of shaft did drain the oil found no metal was found so i need to find a one ..
You need look no further than this site.
