mazzmaint2
New User
Forgive my ignorance, this is my first post and first time working on a tractor. My father in laws 1975 Ford 5600 tractor caught on fire in his barn, saved the barn, but tractor heavily damaged. I replaced or rebuild all mechanical needed to make tractor start and run. The only wiring harness I could find was for a generator type tractor, this one has alternator. D3NN-10306-B is the part number of the alternator. Regulator needed is part # D7NN10316B as I understand it. Bought and installed. I know where green field and ground go. On harness I have hot from battery, battery wire from alternator, hot to ignition. I have red (battery) on regulator and yellow (ignition) from regulator. Not sure how connections go together. Only have wiring for generator type setup. I am sure it is a simple problem but need some help and don't want to start another fire! Any help would be greatly appreciated. Thanks, Mike in TN
