Mike Knowles
I have a used Ford tractor. From what I could find out it seems to be a 841D. SN# eaten away via battery acid or just weather exposure . I was fine with that. But, it came time to replace the clutch. 1. clutch plate is a 10", 1" 15 spline with a 2" wide contact area as apposed to the typical 1-5/8". NO PART NUMBER that I can find. 2. The release/throw out bearing has a grease way. Aetna #2256-30 AKA All States Ag Part #1428650 maybe. It can be greased via a zerk and hose mounted to the bell housing to the hub. 3. The release bearing hub has no typical part number that I could find because, of the approximately 1/4"NPT or FIP tapped fitting. It is stamped "CONN" "7571-A". I found 1 of possibly 4 in the entire world. I had to order it via Ford/Newholland Tuscon Az. SO WHAT KIND OF TRACTOR IS THIS WITH THESE PARTS? I saw an old Ford brochure that showed an Industrial that looked like a 800 series. So, I'm not sure. Any body had any experience like this, or any resolve?
