3000 3 point hitch
dleefarms
I just had to remove the rockshaft housing for bearing replacement. When I re-installed the housing I made sure the lift arms were down and
the positioning lever was in the down position. However when I got the tractor started the lift arms would not raise - any thoughts? Thanks
in advance.
May need to prime the system. Up-down-up down on the position control till it primes itself if all you need to do is get rid of trapped air.
