techegirl71
New User
We have a 73, Ford 3000 Gas
We have changed points, condenser, fuel pump, fuel shut off
valve, coil, rebuilt carburetor, and still it runs for a few minutes
then acts as though it?s not getting fuel. My questions are.
1. Should the sediment bowl be full always?
This one runs about an inch shy of full but has enough in it
that it?s not sucking air.
2. The generator shows 13 on the volt meter and I know it
should run at least two volts above battery? The battery is a
12 volt. So I?m wondering if this is an issue?
Tonight it ran for about 15 min so we thought it was all better
but took it out for a trial and spit and sputtered and died. Let it
sit for a few min started up, spit, sputtered, and died again
and again. Finally limped it back to shed and gave up. Been at
this for three weekends already. Am about to give up.
I?ll post more questions as I think of them. Thanks ahead of
time for any help you can give.
