stangman39
New User
I noticed the front right axle hub started leaking after sitting with no use for about 3 weeks.
I'm going to have it checked out and hopefully just needs a seal replaced. In the mean time if I need to use the tractor is the only place to top off fluid on the front axle is thru the little dip stick bolt to the right of center on the axle? Or does each hub have a fill area?
Thx for the help
Thx for the help
