OldFord860
New User
I've been struggling with my three point not working for a long time. I replaced all the gaskets and O-rings in the main housing (under the seat) and that helped a little.
The three point will stay up well once it is up, but it rarely goes up. When it does go up it is VERY jerky and slow.
I've been trying to bleed they hydraulics. I put a rubber hose in the bleeder valve, put the other end of the hose in a jar with a little hydraulic fluid, then started the tractor and slowly opened the valve.
As expected air and fluid came out. Unfortunately, air and fluid keep coming out. No matter how long I let it run, it never stops blowing bubbles in my jar of fluid.
Do I need to rebuild my piston pump?
