FlatFenders
This message is a reply to an archived post by MarkB_MI on June 26, 2008 at 19:37:42.
The original subject was "Re: Hydraulic or 90 wt. oil in Ford 601 Workmaster???".
Just found this thread from a long time ago. Hope you are still active. Based on your comment, can I use the same UTF for the SOS transmission, the differential, and the area in between that I assume is the hydraulics? I have 3 drain plugs on the bottom of my 1964 4000 SOS Row Crop. UTF came out of the front (transmission), gear lube came out of the rear (differential) and some gray colored sludge came out of the plug in the middle that is under the output shaft disengage sleeve.
