Texasmark1
I noticed that the thermostat for 1965 and up is 188 opening according to supplying sources. Full open is 192 as I recall. That's up some 20 degrees from the earlier spec, pre-65, as I recall. Some run with a 7# cap and others with a 13. I'd assume part of it is cleaning up the environment....EPA thing.
Comments on what and why (your experiences) would be appreciated. Current condition appears to be no stat or if so, a mighty efficient diesel in my newly acquired 3910. Installed a new inst. panel so it's not a meter problem.....could be a sensor problem if there is a problem with the tractor and it does in fact have a 188. First time I get it out and work it I'll take along my non-contact Infrared thermometer and take some points. I don't want this kind of performance this winter.
Thanks
Thanks
