Mission Creek
On a 63 4000 4 cylinder gas select o speed... I?m missing whatever linkage is needed to hold the sleeve that mates the output shaft of transmission to the rear axle. The round access plate would be sitting by your left heel almost level with the running board. Has a dip stick in it as well. There?s a bolt that goes through ithe cover with a lever on the end, holds the sleeve inside the housing from sliding off and tractor going into neutral. On the outside, mine is just bare ended with nothing holding it in place. Is there supposed to be some sort of linkage holding that arm still? My sleeve keeps sliding off and then I have to take the round cover off and pull it back in place. Anyone have a picture of the factory set up so I can make something or buy it? Thanks
