Help identifying a Ford 3000 made in England
TractorLover
New User
I have an English made Ford 3000 with stamped behind the starter is, 7D 27[/b. Under that is *B836935*
Been having a hard time figuring out what your model this is and it looks like it's built differently than the American made models of the Ford 3000?
7D27 looks like a date code, which would be July 27 1977.
B836935 is the serial number, and that would be a 1977 serial number for a tractor made at the Basildon UK plant intended for "domestic" sale.
There should be a third number up in the rough part of the casting above where you found the other numbers. athat would be the model number which would tell us if it were indeed a 3000 series tractor, which specific model within the series, as well as whether it had a gasoline or diesel engine and which transmission and PTO options it had as well. If it is a 1967 3000 ag chassis model then the model number should start with 310 followed by two more digits and a letter.
