SO I'm fairly new to the tractor world. I've driven a few growing up, and my dad has had a 3 cylinder 820 john deere for a couple years. But I recently bought an International 460 utility with a Ford 725 loader. I've had work done to the tractor and
bailing hay and planting corn with it went well. The loader was off for both of these task. However I put the loader on and its as if the loader doesn't have enough fluid to raise and lower it. IT will raise and lower, but very slowly. I found a manual and
it said to put hydraulic fluid directly into the loader. I have never heard of that. The manual said it would need about 9 gallons. I checked the filler cap, which is a small hole for filling hydraulic fluid i thought, and it was empty. That would be the
problem. My question is, am I actually suppose to put the hydraulic fluid directly into the loader? If so, what does the receiver feed, as i see no outside outlets on it going to any of the hydro lines. Thanks.
