Larry B 1486
I am having problems starting my 5000 diesel with out using starting fluid. About a month ago it started missing out so I changed the fuel filter. Solved that problem. Then after that every time I went to start it, it always took a little more cranking time for it to start until it just would not start at all with out using eather. When cranking, it smokes so its getting fuel. Just a little shot of eather is all it takes even after sitting only 30 mins. It runs good, pulls good. Will not fire at all even with it being 90 degrees outside with out starting fluid. Anyone have any ideas????
