good to meet texforfan
Larry NCKS
hope you made it home or are making it home safely. You can tell 'em what your problem was if you wish. :) I'm keepin' my mouth, 'er keyboard, shutted up! :lol:
It's all right. I'm a newbie and so these things happen. Heads up guys, if you split your tractor (between tranny and rear end), make sure the drive
coupler is put back on the correct way. It will go on either way. If you get it backwards (I did) the coupler can self disengage and you won't be going
anywhere until you split the tractor again and reverse it. It was well worth the trip to have someone figure it out and I'm very thankful that it wasn't a
rebuild of the tranny. Also good to get that PTO adjusted.
