Hogfarmer10
New User
Need some help. We have an 8700. Using it last week pulling manure spreader, turned PTO on, and an unbelievably loud whining came from under the floor board, PTO would not turn, nor would either rear remote work. I was able to get it home and unhooked, however the tractor would not pull itself to the shop. I just assumed it was the hydraulic pump. I put this last one in about 10 years ago. So, I put a rebuilt pump in today. No improvement whatsoever. Same symptoms. I will add that I am unsure if it ever primed, but I do not think it did. I did fill filters up with oil before I started the tractor to avoid a dry start. Any help? Getting desperate here. Thank you.
