sammorgan3
Found another area that may need attention for round 2 of my "working restoration." Rocker looks pretty worn, has a fair amount of slop. Is this part cast iron or steel? I'm guessing cast iron so I'll probably be brazing that hole up before boring it out. Main question is how does this hollow pin come out? Does it just press out or is there something hidden holding it. Pin isn't loose in the rear end, I couldn't move it by hand anyway. Rocker has a good bit of flop though.
I think it'll handle the bush hog to cut my other little 3 acre place once it dries up but looks like it'll need attention soon. Probably just make another pin, According to Sparex it's just a 1" OD x .106 Wall pin about 3-15/16 long, no big deal to make on the lathe. May not even need to build back the bore on the rocker with a new pin, the one in there looks sort of worn on the back.
Picture of rocker: https://imgur.com/a/DDuWSmy
