The front wheels on my 3600 are set pretty wide, one position wider than my 3000, lined up with the outside of rear wheels verses inside of rear wheels. When turning the 3600 digs in quite a bit more than the 3000 and if you are not careful the front wheels will make a pretty good rut, much worse than the 3000 and the 3000 has a loader on it. I checked the alignment and set the toe-in when I replaced the bushings last winter.
Could the wider wheel setting be the reason it digs in much worse than the 3000?
If I move the wheels in, how far out will the toe-in be? Those adjustments are a bear to turn, I had to use heat, PB Blaster and a big pipe wrench, not looking forward to resetting the alignment.
