1962 Ford 4000 Industrial Tractor Power Steering
duffejo
New User
I need assistance determining the type of pump this is and a way to rebuild it. I can't seem to figure out, it appears to be an EATON style roller pump. Pump has 153-5N cast into housing, this is on a 1964 Ford 4000 Industrial Gas Engine Tractor.
(quoted from post at 17:54:02 05/21/18) I need assistance determining the type of pump this is and a way to rebuild it. I can't seem to figure out, it appears to be an EATON style roller pump. Pump has 153-5N cast into housing, this is on a 1964 Ford 4000 Industrial Gas Engine Tractor.
Would this be the correct repair kit for anybody knowledgeable enough?
https://www.external_link/ABC3275-Eaton-Power-Steering-Pump-Seal-and-O-Ring-Kit?&TF=F3FADCA9F397
You are supposed to check the end clearance of the gears against the pump body for wear, some are unservicable. You can buy a new copy of the pump body from JC whitney or fleabay for about a $100. Their search engine isnt what it used to be, you have to look through a lot of their hand picked sellers to find anything, I couldnt find the JCW one.The only difference is it doesnt have a flat machined surface for the banjo bolt pressure line. It may be a NPT fitting. Someone else on here posted about their installation. Heres the item number for a rebuilt body 232743324709. You might want to take a pick of how the tank comes off, If you put the thick steel plate with 2 holes back on wrong it will crack your metal around the holes. I would also order the OEM Ford orings for the tank.
Anybody have any technical data as far as dimensions of rollers, gear (diameter/length/etc) so i can check for wear. Any body aware of building new rollers out of solid steel or heavy wall tubing? I hear these are really good pumps.
This is a little off the wall but, here goes.
I looks identical to the one on my 1960-61 841D.
It may be a like a CONN3A674H and/or maybe a
Ford Mustang 1964-1965 Cardone Select 96-6052 Power Steering Pump. New for $65. I'm not sure of the pressure they can run at. I sent that question, to Cardone, waiting for a reply.
If you have the drag link assisted power steering you need 1350psi and if a straight industrial, you need 1500psi.
