REMOVING BUSHINGS NAA FORD
pinball
I decided to replace my bearings and bushings on my spindles on my naa ford tractor. Need some input on how to remove the bushings. thanks norm
How good are you with a cutting torch.
That's how I take mine out.
Takes about 30 seconds to make two slices the length of the bushing and the two halves pretty much fall out.
If no torch maybe you have a sawsall?
Two cuts made lengthwise in the bushing with a good metal cutting blade will accomplush the same thing. Just takes a few minutes longer.
