fran213
I installed a new hydraulic lift cylinder and piston.I used Zane's jig to make the adjustments .The lift will go p and down but will not
lift with a load attached to it.Is thee an adjustment I need to make ?
Thanks
(quoted from post at 09:30:41 05/20/18) I installed a new hydraulic lift cylinder and piston.I used Zane's jig to make the adjustments .The lift will go p and down but will not
Thanks
hain lift arms down and measure pressure at test port.
doesn't sound like he needs to chain 'em. Just put load on 'em that they won't lift and measure pressure.
fran213, there is a forum in YT dedicated strictly to the N series tractors. May be more help over there.
