Select-0-speed PTO cable parts question
gofast12
I have a '64 4000 4cylinder with a select-o-speed. The piece that comes through the hood has stripped threads on both ends. If I disconnect the cable will it pull out through that cast piece so I can just replace that cast piece if I can find one?
Someone just posted on that a day or so back. Click on modern veiw and at the search bar at the top type in SOS cable replacement. When the page resets hit search again. I hear you have to be careful around those when they are running.
[u:af2d972d1e]
(quoted from post at 20:14:26 05/17/18) I have a '64 4000 4cylinder with a select-o-speed. The piece that comes through the hood has stripped threads on both ends. If I disconnect the cable will it pull out through that cast piece so I can just replace that cast piece if I can find one?
You must be talking about the PTO cable???? The T handle unpins from that assembly. Other than that, the only piece that should be removable from the body is the conduit. It should only be removable from the cable if the entire assembly is separated completely from the tractor.
[b:af2d972d1e]DO NOT[/u:af2d972d1e][/b:af2d972d1e] . . . and I repeat [b:af2d972d1e][u:af2d972d1e]DO NOT [/u:af2d972d1e][/b:af2d972d1e]attempt any of this without a thorough knowledge of procedure or you'll have more problems than you know what to do with.
