I just picked up a full set of pie weights. It is the “regular duty” set, with each segment being 30 pounds (though the actual weight of the one I checked was 32.5).
The set was complete, except for the lug extensions. I have been able locate 8 lug extensions. I’d like to get the rest, but they are ridiculously expensive, when they can be found. I’m wondering if anyone here has tried to run the lighter weight set (roughly 400 lbs. per side) with fewer than 8 lug extensions per side. Can I get away with four per side?
After I bought the weights it occurred to me to check the manual for what it said about wheel weights. I’ve attached the chart. It shows that the set I got is meant for the 600 series only. The centers (mounting plate) looks like it will mount on my 850 without issue. My assumption is that both sets can be used on the 800 series, but that the heavier set is what is recommended. Is there any reason the lighter set should not be used on an 800 series?
