corvetttteguy
I am not sure my draft control is working properly.
If I am in touch control and lif an implement 1/2 lift.
Then move the lever down to Draft Control implement
drops to ground.
If I then lower touch control and then raise
it the implement starts to rise. And can be set.
By setting it after it is in Draft mode should it operate?
What sensing is done on the Hydraulic spring to
the top link?
Is it just measuring the tension caused by pulling
the plow when it is in the ground?
And using a stone rake would not work?
drops to ground.
the top link?
