Tom Bond
Was just out tinkering around putting the lift cylinder back on the 711 loader after putting new seals on it. Anyone know where the stress points are on the tractor for one of these? Are they the brackets themselves or is it the lower bar that connects the arm to bottom of tractor? Has anyone ever broke one? Bracket? Cracked case on bottom of trans? Just curious how much they'll take before damaging anything.
(quoted from post at 19:49:19 05/12/18) Was just out tinkering around putting the lift cylinder back on the 711 loader after putting new seals on it. Anyone know where the stress points are on the tractor for one of these? Are they the brackets themselves or is it the lower bar that connects the arm to bottom of tractor? Has anyone ever broke one? Bracket? Cracked case on bottom of trans? Just curious how much they'll take before damaging anything.
Hi, Tom,
can you tell me how to remove the piston from the cylinder?
does it require a special tool??
