1960 ford 841 touch control lever
Akpdp
New User
I have removed the seat cover to look everything over for the hydraulic system. where the touch control leverlinkage where the crown nut is supposed to have that much slop play in it? Also where can i buy a replacement rod that goes from the lever through the case all the way to the linkage?
Its slop is probably from wear. Ill look to see if I have the shaft. You mean the one that the handle attaches to, right?
