861 Ford HYD Remote
need more information. Single acting cyl or dual? What is remote connected to? Which way is slow? ?????
(quoted from post at 06:33:40 05/06/18) need more information. Single acting cyl or dual? What is remote connected to? Which way is slow? ?????
It is hook to a front end loader down is much slower
(quoted from post at 16:19:34 05/06/18)
f single acting, then only gravity lowers it. If dual acting, then investigation may be needed. Also, sometimes there is a one-way restrictor inline for the purpose of slowing drop in single acting installations. Single or dual?
It is a duel acting cylinder and it did work fine both ways and it started slowing done until it will hardly moves.
reverse the up/down hoses & see if problem reverses. If yes, then I would look for a valve problem. Or swap the lift and bucket tilt connections & observe.
