851 air cleaner
MeanGene1
The new to me 851 I just got is missing the complete air cleaner assembly. Will the one sold on this site, which appears to be the same one sold on ebay etc, work on the 851?
http://www.yesterdaystractors.com/C7NN9600J_Air-Cleaner-Assembly_20255.htm
The air cleaner for the XX1 tractors is larger than the one for the XX0 tractors. From what I can see it looks like the one that is being offered is for the XX0 tractors. other than diameter and the clamp that holds the cup on they are pretty much the same, so it should work on your 841. The steel tube that runs down to the carb is smaller on the XX0 too, so you would need and adapter at one end or the other. the screw holes may not all line up either.
