4000 Select O Speed PTO Cable
Does anyone know the proper way to replace the PTO cable on a 1964 Ford 4000 Select O Speed?
I have all the aftermarket manuals but they are little to no help on how to remove and replace one of these.
This is from my 801 service manual but should be the same.
This is going to be long cause I can't get a good photo of the pages.
Select-O-Speed PTO Control Assembly Repair
1. Pull out on the control handle and unscrew the nut so the knob assembly is free.
2. Unscrew the conduit nut at the transmission cover. Loosen the conduit nut at the front end of the knob assembly, then turn the PTO handle clockwise until the cable is free from the transmission.
3. Knock out the handle pin and remove the handle, nut, and lock washer
4. Remove the conduit and knob-cable assembly. Unscrew the conduit nut at the knob-cable assembly and pull out the cable assembly.
5. Inspect the conduit for kinks or breaks. Inspect the cable for wear or damage.
6. Install the knob-cable assembly in the conduit and install the conduit nut but do not tighten at this time.
7. Position the conduit and knob-cable assembly on the tractor. Slide the lock washer, nut and handle on the knob-cable assembly, then secure the handle with the pin.
8. Pull the handle out (rearward) and feed the PTO cable into the transmission by turning the handle counterclockwise until the lower end of the conduit is tight against the cover fitting.
9. Position the knob-cable assembly so the tab in the hood engages the grove in the knob. Thirteen the nut to secure this position.
10. Tighten the top and bottom conduit nuts and check the PTO control assembly for ease of operation. Also check for PTO disengagement with the handle "IN". If the transmission lubricating light is on, other than when the knob is at a midway position, the cable is not threaded far enough into the transmission
