FORD 600 problem
GaryinKs
I have a Ford 600 that backfires when it warms up, I replaced the points and condenser,it has been converted to 12 volt, the coil
is new also, any ideas on what would cause this? We have o,wned this tractor since 1977 and this problem started last year
you can buy a brand new carb for it on ebay for 60 bucks. that's what I would do if it were mine.
When does it backfire, I understand when it's warm. Does it backfire on acceleration?, deceleration? Pulling a load?, or on restart?
Ck firing order, ck inside of cap for carbon tracks. If it's backfiring in the carb on acceleration or load could be lean. Ck fuel filters and ck for any vacum leaks at intake or carb. Did it do it before points installation? Did you ck ignition timing? Ck valve adjustment. Do a compression test.
