2k1bmw330i
New User
Hi new to the forum here. i bought a ford 5000 diesel. previous owner put two head gaskets in it. question is is it is smoking white pretty heavy and it has a hard time starting up when its cooled down needs ether, when its warm its a long crank but it will start up. now ive been doing some research and noticed that 1968 is the cut off for thick and thin headgasket. as far as i could tell when i looked at serial number mine is made 01 of 1968 the guy put a headgasket from a 1975. he didn't know the year so he ordered for 1975 so that telling me it has a think head gasket in it when it should have a thin headgasket in it????? any thoughts would be helpful. have not done a compression test but I'm thinking its a little low causing unburned fuel and white smoke which maybe could be all caused by headgasket? has new rings in it also and head was sent out and tested
