JMOR, Test results from Gen, wire to VR A & F disconnected Made jumper gen A to F and jump to Neg. battery post belt off motor test ok
volt 6.21 battery volt nothing hooked up 6.28 battery on running at idle volt 6.16 hook up jumper volt 5.78 speed up volt 5.75
1 min running volt 5.76, 2 min 5.77, 3 min 5.76, Jumper off and stopped volt 6.11 rising up to 6.17
If these # are what you asked for on testing From what you have told me, the charge rate should be up in high 6 to 7 volts when charging.
So you would say Generator is no good? I did change the VR no change at all react the same as the last one I had on it.
