BarnabyHooge
I took my top cover off today thinking something was wrong with the linkage or cam follower pin, but everything looks brand new. What doesn't look brand new is the lift ram which has broken in two. I also discovered there is a hole in the back of the cover by the main spring that looks to have been patched with JB weld.
I see I can order a new lift ram and shaft, but I'm curious what the issues would be if I cobble up another patch job for that hole on the lift cover. Is it likely to be something I could find in salvage instead?
