Gauge of Wire
What gauge wire is ran from a solenoid to ignition switch, and then gauges of wire ran from ignition switch to the coil in a 1963 Ford tractor? Any specific wire type as well?
Id run 12 from the switch on and 16 from the solenoid to the switch. That way if you have a short the 16 gauge will act as a fuse link.
(quoted from post at 18:49:50 04/13/18) Id run 12 from the switch on and 16 from the solenoid to the switch. That way if you have a short the 16 gauge will act as a fuse link.
do believe that the wire to/from solenoid will be carrying full generator/alternator current. If it is in fact wired that way, I wouldn't use less that 12GA for that one.
Thanks everyone.
I am rewiring my initiation circuit from solenoid to coil and was curious. I am going to wire it up using 12 gauge since that is what I have on hand.
