I just bought a 1957 Ford 860. It's a little rough around the edges but seems like a solid tractor. It starts right up but the carb seems to not be working properly. It has trouble going from no load to load situation, it tends to die if you don't give it heavy choke while letting out clutch. Adjusting per the shop manual hasn't offered much improvement. I ordered a carb kit but noticed the listings seem to all show my carb (Marvel TSX765) listed under the 600 and 700 134 CID models. It has me wondering if someone replaced the original with one that looked the same but was for the smaller engine. Does any one have info as to what MS carb models were used on the various hundred series tractors? If this carb is undersized or under jetted a rebuild isn't going to help me much. Thanks!
