WOW! The surprises on this tractor keep on coming! In the first pick you can see where someone welded that plate on to stop the crack on the tube. The crack must have gone all the way around.
The crack is at that joint up front near the bucket on the inside. Where is the drain plug for the loader frame? I assume the frame is the reservoir for the fluid? I also assume I need to drain that fluid out before I start welding on the frame tube? Hate to start a fire!
