Which Loaders Fit My Ford 5610?
Nisani
New User
Have been looking for a used loader for my Ford 5610 2wd with ROP and 777Bs are really hard to find. What else will fit? Since I will have to travel some distance to pick it up when I buy, is there any source of info I can check to be sure the loader fits before I haul it home?
Westendorf and Allied on a lot of Ford's that size around here. Check with the manufacturer's web site or google if you know the model number. Still might need different mounts depending on tractor make as one loader will fit many brands and models.
Thanks! I tried checking the web, and their sites, but it's harder to find what you are looking for when you want to buy used.
Ford 5610 with Westendorf WL-21
Lots of Bush Hog brand loaders in this area, light models 2246QT thru the heavier 2847QT will fit a 5610 with the proper brackets, you may find a used loader from a different brand tractor and purchase to correct brackets for your 5610.
Same applies for other brands as well but check on bracket availability before purchasing a used loader.
For example brackets for my Farm Hand 22 loader are no longer available.
Westendorf TA26, but like was mentioned, you need
the right brackets. Try looking for one that is/was
mounted on a '65 or newer 4-cylinder Ford. Except
for the rowcrops, they all use the same brackets.
I have a TA26 on my 6610, heavy loader, seems well matched, do not know how much bigger a 6610 is than 5610.
I don't know where you are at if you don't need a quick attach there is a 727 loader craigslist Jackson Tn for $1200 and a Schwartz quick attach in Youngstown Oh craigslist.
Well thanks for all of suggestions I checked the internet to see if any of the brands suggested were available near me, and couldn't find anything. I will keep looking but...
...I located a used White 1730 QA. The question is, should I buy it? It has been sitting outside for years, I am not sure how many. The seller notes that the cylinders are basically retracted, and the loader has oil reservoirs and aux valves but it has been out in the weather. There are no brackets so I would have to get those made. I am new to this so don't know what I am getting into. I do know a welder.
I am in Virginia, but willing to drive some distance to get a loader that fits. I regularly drive between Virginia and Ohio so can pick one up along the way.
