tie rod for 62 4000 row crop
tractorguy2
Dad has a 1962 4000 row crop with wide front axle. This is the same basic tractor as a 971. One tie rod on the front has been
welded on both ends so it is not adjustable. Dad needs a complete tie rod assembly. Have called a couple of junk yards. No dice.
Anyone know where to buy one?
This could be very difficult because of the much higher production of narrow fronts to wide fronts, and the tendency to replace narrow fronts with wide. You may need to find ends and cut and weld to length.
I'm not sure of the length or the stud size but its about the same size as a 71 GMC 4x4 arm that goes from the steering box to the axle. If your looking for correct I cant help you there.
