8N brake drums stuck
Have the wheels off my 1952 8N, as it's time to check the brake shoes and springs after 30+ years. Got the four bolts out of the brake drums, backed off the shoes, so now the drums should pull off, right? But they're not budging. Have I missed something that's holding them on, or is it time to use the big puller?
Yes, if you have the four holding screws out and have backed off the
adjusters (instead of tightening, don't ask :oops: ) they should
be free. A big hammer, or big drift and hammer between the studs
and around the hub may help break rust loose.
I've had to heat them before, but with the seals and grease, I save
that for a last resort and then use it pointedly with a puller.
